no way to get at it. even with the trans mount removed it won't drop enough for access to the top of the gearbox. ideally you want the vent on the top of the gearbox as far away from the gear oil as possible.Sean. Do you know a way to stop the leak out the top without removing the engine/transmission?
I was thinking of adding a breather like you have to the fill port. I would add height to the fill port with pipe and finish with the breather. Thoughts?
