KenF
Damper Sleeve
Noticed the harmonic damper had a worn groove from the seal. Instead of trying to adjust the seal in the timing cover to ride the surface at a slightly different location, decided to install a sleeve on the damper.
Put the damper in the freezer for a few hours, and the sleeve in boiling water right before adding a little sealant and pressing on using a wood block. New diameter is 1.900 vs the original 1.875, should work fine.
