Stripped
Time to post what happened the last weeks.
Removed both axles and the complete drivetrain without big issues.
Had to scrape off about 4kg of backed on oil mud from the diff.
I will open it and look if there even is some oil left inside, what I dont believe.
I removed engine and tranny by lowering the car on the rotisserie untill the stuff was lying on a dolly.
I unscrewed everything but the last two screws on the motor mount bevore lowering, so I just had to loosen the two screws, pull the tranny out of the frame and lift off the tub.
I must say that now I am very pleased with how the Rotisserie works, you just have to pay close attention to these damned Jacks while lowering...
When i had the engine out, i noticed someone had taken off the upper screws from the Bellhousing... why would someone do that?? so the engine was only hold to the tranny by 3 bolts...
Now i will wait for the replacement panels and till they come, will dissasemble the axle stuff.
I will post some more pictures of the engine bay and hidden stuff these days, as i want to clean everything bevore taking pictures.
Regards,
Thibaut
