Approach I took...
I didn't mention it in my original posting, but one of the benefits of the approach I took has to do with "rain." Not that my Tiger sees that much of it now days, but it has on occasion. By taking the approach I did, any rain (or water) that enters the vents is contained by the inner channel (it does not fall into the engine compartment). You'll notice that the "exit" holes I drilled in the channel are on the inboard side of the channel on each side.
The water that enters the vents flows down the outside edge of the channel, as the inboard side is higher... that is, the channel slopes down to each side. Then, it exits at the factory drain holes at the front of the channel, etc.
Not a big deal... but some of the "open vent" cars shown in photos would definitely let water drop on the engine. Yes, I still have not addressed the water that might enter at the front of the hood scoop. But, I have a plan to design and build a housing that would seal the air intake to the hood and direct the water into tubes extending to the bottom of the engine compartment. Similar to the approach Ford took on the Boss 302, etc back in the day.
Bill
