Carbuilder
I'm planning to drop the engine/tranny soon to tone down the engine as a winter project. Currently a 347ci with 426HP, high compression (around 10.9:1), high idle, very heavy clutch, and a bit of a lumpy idle. Perfect for some people that want a hotrod but not what I want. The car is great other than that, so I want to tone it down a bit. The plan right now is to install lower compression pistons and a very mild cam (16cc pistons as opposed to the 5cc ones in it now should put it at about 9.5:1).
This is a well modified car with a "Hokanson" front suspension. I've had a good look at it and this seems to be the plan to remove the engine/tranny. I have a 4-post lift and am going to get a heavy duty tranny jack to support the engine/tranny for removal.
The transmission is a T5 that ends about where the line is drawn, so would have to come forward about 9" before it can be dropped. But looks like the engine can be lowered down at the front and maybe go forward/down to not have to pull everything straight forward 9", if that makes sense. But I'm going to remove the rad to get at the electric fan, so with that and the front pulleys removed it can come forward quite a bit.
Support the car on jack stands here:
This is the front suspension. Looks like 1 brake line to undo and the steering joint:
2 bolts on each side to remove the suspension unit:
The plan is to remove the wheels and have the car high enough on the jack stands to remove the suspension unit, supported on the tranny jack, lower it a bit, swing it 90 degrees, lower it and out.
Looks like there are 3 bolts in each engine mount attaching it to the frame. The headers are wrapping around the mount, but looks like the engine/header/mount can all be dropped down. The header may have to be loosened from the engine, but looks like almost/maybe enough clearance to drop it down just clear of the frame.
There will be some removal from the top (alternator, front pulleys, anything else that looks like it is in the way).
So that is the plan. See anything I am missing?
